Re: need help with M carb
Posted by DigDugNC on January 01, 2006 at 20:11:58 from (172.131.183.137):
In Reply to: Re: need help with M carb posted by Nebraska Kirk on January 01, 2006 at 19:58:49:
The same thing happened to me and I kept doing the same things your doing until finally something worked. I don't know if this will work or not but at this point your probably willing to try anything. With the tractor running full throttle turn the fuel flow rate screw (its the screw on the side of the carb that is closest to the governor) clockwise until the tractor slows down and almost stops (cutting off the fuel) then quickly back off just a little bit until the tractor runs smooth again. This will keep the flow rate of the gas to just the minimum amount needed for the tractor to run sufficient. Reduce your engine speed to idle and see if that works. Let me know I'm currious now!
