Re: MTA TA Clutch
Posted by captaink on January 03, 2006 at 09:27:15 from (66.115.214.56):
In Reply to: MTA TA Clutch posted by Andy Martin on January 03, 2006 at 08:57:02:
Been a long time since I had one apart, but seems to me there is a “throw out” type bearing that will run against the fingers to disengage the clutch and allow the planetary and sun gears to do their thing. Check that there is some clearance between those fingers and the bearing and check the linkage adjustments too.
Post back with what you find.
