Re: 6v to 12v conversion ... ignition problem
Posted by Randy Glasnapp on January 03, 2006 at 10:24:30 from (216.192.195.7):
In Reply to: Re: 6v to 12v conversion ... ignition problem posted by El Toro on January 03, 2006 at 03:41:21:
You were correct.
I was getting almost a 6v drop while starting and apparently this was enough of a voltage drop to make the coil not fire. While I knew I had an old battery I thought the Commercial Heavy Duty battery charger/starter would provide enough volts and amps. I thought the starter would have dropped off line before the coil didn't get enough power to operate ... I was obviously wrong.
I connected another battery directly to the coil and the plugs fired as advertised. Unfortunately, I couldn't get the engine to start even with starter fluid ... but at least now the plugs are firing at the proper time.
Next step is to get a new battery and look at my carbureation system.
By the way, regarding the connections to the solenoid ... I had disconnected the wiring harness as I did not want the 12v to power 6v controls/gauges/sensors until I had the engine running on 12v. I wanted as simple a system as possible.
Thanks for your help and insights ... Randy
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
