Re: Crank shaft
Posted by El Toro on January 03, 2006 at 13:14:24 from (205.188.117.73):
In Reply to: Crank shaft posted by Famall lover on January 03, 2006 at 12:54:07:
I think you should've used engine oil on the pistons, sleeves and bearings. You could 've used
lubri-plate on the bearings too. I'm not sure about how much clearance you have on your bearings
using grease. A film of oil doesn't take up very
much clearance, somewhere around .001" to .0015."
The grease may keep your rings from seating too.
It's very important to have these parts well oiled during the initial startup.
Your oil pump needs to primed too in clean engine oil. Hal
PS: You should've posted here first.
