Re: will 350 3-valve fit a 350 utility?
Posted by AJB450 on January 03, 2006 at 14:09:26 from (70.105.100.31):
In Reply to: will 350 3-valve fit a 350 utility? posted by robert mangus on January 03, 2006 at 06:22:40:
Robert,
I have a 300 utility with factory power steering, fast hitch, loader, and 3 hydraulic valves. The power steering priority valve is mounted at the rear with 1 one hydraulic valve on the outside. The other two values are located to the front. There is a pipe that feeds oil from the rear valve to the front valves. The rear valve operates the fast hitch and the two front operate the loader. As Hugh MacKay said, the valves are the same as on a row crop 300/350 but you will need to find the hand levers from a 300/350 utility. I believe the hand levers are also the same as on a 600/650. Send me email if you have questions about this setup.
Al
