Re: H hiting and missing
Posted by old on January 03, 2006 at 15:13:34 from (207.69.139.160):
In Reply to: H hiting and missing posted by Walt La on January 03, 2006 at 14:35:14:
When you replace the cap you should replace the rotor and when you replace the point you should replace the condenser. A bad rotor could cause that problem, or it could be the carb. Popping like that can be to much or to little gas. I'd get a crab kit and fix the gasket problem and also I would replace the rotor and condenser.
