300 Farmall Points
Posted by IaGary on January 03, 2006 at 15:14:07 from (207.32.0.78):
Opened the distributor to work on points and the shaft that turns the rotor has a lot of sideways play in it. Is this common until you put the plastic plate thats under the rotor on? Seems to me this would wear into the plastic plate. Also wondering if I can put electronic ignition on a 8 volt 300? What does it cost? Thanks for any infro.
