Re: 300 Farmall Points
Posted by John T on January 03, 2006 at 16:12:13 from (66.244.90.98):
In Reply to: 300 Farmall Points posted by IaGary on January 03, 2006 at 15:14:07:
Gary, I would be afraid if theres too much distributor shaft wobble, its more of a bushing/bearign problem versus any plastic or dust cap etc type of thing. However, even if you swap to an electronic ignition unit, too much shaft wobble can affect them adversely plus the timing as they work pretty close tolearnces where a magnet placed on the shaft passes by BUT CANT COME IN CONTACT WITH the pickup coil. It seems the standard elec. ignition are for either 6 or 12 volts, but like Hal mentioned Pertronix will have to answer that question as theres often a failry wide operating voltage range on some of that type gear. It might take a small amount of added coil ballast also if using a 6 volt coil, they will know. You may wanna consider just upgrade everything to the more standard 12 volts???
John T
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
