Re: Thanks CNKS NAT2 JIM N
Posted by gene bender on January 03, 2006 at 15:55:40 from (66.43.221.211):
In Reply to: Re: Thanks CNKS NAT2 JIM N posted by stu in njo on January 03, 2006 at 12:09:47:
Tha 8v is a good quick fix stay with pos ground and no need to do anything else. This has been done for many many years and it just works. The batts can be found at any CAR QUEST and fit in the original batt boxes just fine.
