Re: Steering box question
Posted by Hugh MacKay on January 05, 2006 at 09:12:11 from (216.208.58.167):
In Reply to: Steering box question posted by mitchp on January 05, 2006 at 06:51:24:
mitch: Drain the gear oil before you add the grease. I take the plugs all out, put a zerk in the fill to level hole. Any Moly grease will work, just keep pumping until it comes to the other ports individually, then replace those plugs. The secret with this is having the steering box full of grease, then any new grease you add will go to worm, gear and bearings. Your initial fill up will require almost 2 tubes of grease. After that I just give it 5 pumps of gun every time I grease the tractor. I have two guns one I keep with moly grease.
