Re: Farmall c engine timing quesitons??
Posted by El Toro on January 05, 2006 at 18:31:05 from (64.12.117.13):
In Reply to: Farmall c engine timing quesitons?? posted by T.R.Y. on January 05, 2006 at 17:57:30:
Your timing gear single punch mark is aligned with the single punch mark on the crankshaft gear.
The double punch marks on the timing gear are aligned with the double punch marks on the governor gear.
When you install the mag on the engine you need No1 piston at TDC on the compression stroke. You need to remove No1 sparkplug and hold your thumb
over the plug hole while someone cranks the engine slowly until you feel compression against
your thumb. Then look for your timing mark on the flywheel. Slowly keep rotating the engine until your timing mark is aligned with the indicator. Turn the rotor to No1 position in the mag and install on your engine. Hal
PS: Make sure you feel that compression against your thumb, very important so you're on the compression stroke.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
