Re: Copper Battery Terminals
Posted by BillyinStoughton on January 06, 2006 at 10:35:07 from (208.50.85.56):
In Reply to: Copper Battery Terminals posted by Jay (ND) on January 06, 2006 at 08:27:21:
I can"t vouch for the conductivity of lead, but I will stand behind the statement that copper to copper (cable to terminal) makes for a better connection since like metals are being used. I build all my own battery cables for my tractors and have always used copper terminals. I typically use 1 gauge cable and instead of crimping (and deforming the terminal lug), I solder the copper terminal directly onto the cable. This makes for a 100% positive connection. And since the terminal is filled with solder and not just crimped, it is impossible to get moisture into the connection. Add a little bit of battery cable shrink tube to the equation and you will have the last set of cables that tractor will ever need. I go to the welding supply house for the cable, and my CNH boys for the copper terminals. Rosin core electrical solder works best for the connections and doesn"t require mass amounts of heat. Put the terminal in a vise, insert your cable, and then slowly heat it with a propane torch. Fill the terminal full of solder. As you heat the terminal the copper cable will come up to temperature too. As that happens you will actually see the solder start to creep back up the cable. It"s the best water tight connection that can be made! It"ll cost you about $50 to make a set, but it"s the cats *ss for both 6V and 12V systems.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
