Re: Novice farmer?
Posted by SGT K on January 06, 2006 at 20:21:25 from (209.145.128.34):
In Reply to: Novice farmer? posted by tchr66 on January 06, 2006 at 20:10:49:
Look over on the left side of the page in the GALLERIES section. Open up the TRACTOR PHOTOS and I bet you wil see a Farmall photo that you recognize.
Also look for the serial number tag. It will probably be on the left side of the bell housing (under the gas tank right behind the engine) or below the seat. If you find those numbers the guys can tell you what it is and what year it was built.
Good Luck
Paul
