Re: m timing
Posted by El Toro on January 07, 2006 at 18:49:24 from (152.163.101.13):
In Reply to: m timing posted by in oz on January 07, 2006 at 18:36:19:
The first notch should be aligned with pointer when No1 piston is at TDC on the compression stroke. Then install the mag with the rotor at No1. Try this and see if the engine runs ok.
You need to be sure you feel that compression against your thumb when you're on the compression
stroke.
Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
