Re: Paul hows the timing case on the Magnim coming
Posted by JakeF on January 07, 2006 at 20:10:55 from (64.146.188.222):
In Reply to: Re: Paul hows the timing case on the Magnim coming posted by P Backus on January 06, 2006 at 19:36:32:
I'm hoping you have a book and followed the propper torque sequence for the type of bolt you have. If you have a pre 1991 you could retorque but I have never bothered and it's not called for. The 91-later get so much torque and then an additional 90 degres and can't be retorqued, there is no final value to go to. Hopefully you also checked the bolt free length and liner protrusion. You should notice some improvement from the pump and valve lash. I adjust ours every 1000Hrs and test the injectors every 2000hrs. I only replace the injectors if they test bad or half of the set fails I'll replace them all, and usually they go 4K between replacement on a C series. I do run the engine and then recheck the valves after the initial run to make sure they are all still in speck after the dowels were in the followers. I've only ever had one valve that changed, but it was at .040+ I rigged up a vaccum hose to clean out the follower and got a wood chip from one of my dowels that was holing the pushrod before running but it got smashed when I ran the tractor. Usually they just leak on the right hand side from the headgasket at the rear, but I have seen one that had a leaking liner O-ring. It's easy to check with a pressure tester and the pan off though. Jake
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
