Re: Vibration in idling M - normal?
Posted by Randy-S.E.MN on January 08, 2006 at 07:14:03 from (206.9.216.45):
In Reply to: Vibration in idling M - normal? posted by Dan Crocker on January 08, 2006 at 05:04:53:
I have found that a bent, warped or even excessively loose drive shaft caused vibrations on a couple of my Farmalls. IH did not give precision attention to what is a precision part. They were not cast or machined very true. The center link and wedge bolts may have considerable wear. I fill all the holes and grooves with braze and hand file them back down and redrill.. every little bit helps here...Randy
