Re: Working on the M
Posted by Randy-IA on January 08, 2006 at 10:26:04 from (207.177.83.5):
In Reply to: Re: Working on the M posted by randy hall on January 07, 2006 at 18:55:40:
Hi Randy , This is a stupid question - How to check for up and down movement ? Let me guess first , jack up the front and leverage the lower bolster up and down ? I looked at the parts book this morning and noticed that there are some washers under and over the gear in mine that aren't listed so I assume that someone tried to fix this by doing that . Maybe I need to remove them ? I mentioned on the first post that there was some slop in the gear ( about 1/4" of side slop in the upper shaft ) so I really need to remove the upper bushing and replace . From what I can tell from the parts book the upper bushing comes out the top and the lower bushing from the bottom ? Are they a interference fit or a hand fit ? Is there a special tool needed or just patience and a long punch and hammer ? I'm going to wait on loosening it up till I can get a gasket for it at the very least . I didn't plan on doing that yesterday so I put it back together dry ( no gasket or silicone seal ) . How easy is R&R of the bushing ? Thanks ! ...Randy
