Re: puffed once and the starter stuck.
Posted by Bob M on January 09, 2006 at 09:34:43 from (151.190.254.108):
In Reply to: Re: puffed once and the starter stuck. posted by fisherman on January 09, 2006 at 08:33:55:
You can try rocking it in 5th gear like the tractorvet suggests below. But it must go BACKWARD to release the starter - going forward will be impossible, and could jam the starter even harder. The hand crank won't work since crankshaft must be turned backward to release the starter. (Rachet action by the crank drive only lets it turn the crankshaft forward...) Loosening the bolts holding the starter several turns, then giving the starter a tap with a block of wood always works. (I always kept a 3/4" box wrench aboard my Super H for that purpose only). Don't bother oiling the ring gear - it will have no effect. And if any oil gets past the ring gear and into the clutch you will suddenly have ANOTHER reason to split the tractor! Some guys have had success "sharpening" rounded ring gear teeth with a file or Dremel tool. But it's kinda tedious and it's in a very tight space....will give you a good appreciation for the kinda work your denist does all day. With my tractors I found a new starter drive tends to jam more often in a worn ring gear than does a worn drive. So sticking the old starter drive back on may help get the tractor started. Also before hitting the starter, turn the crank 90 degrees (1/4 turn) from it's normal resting spot. This will present relatively unworn ring gear teeth to the starter and greatly reduce the chance of the starter jamming when you hit the button. Good luck!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
