Re: distributor or magneto?
Posted by RustyFarmall on January 10, 2006 at 05:19:17 from (216.248.75.170):
In Reply to: Re: distributor or magneto? posted by Andy Martin on January 10, 2006 at 03:51:52:
Andy, a battery, generator, and starter were available from the factory in '39. You could also order up a "lights only" package, which included the lights and a sort of generator, but without a battery. Even with the factory starter and lights, the ignition was still a magneto.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
