Re: OT truck problems
Posted by Janicholson on January 10, 2006 at 09:07:44 from (199.17.6.193):
In Reply to: Re: OT truck problems posted by Allan in NE on January 10, 2006 at 05:06:27:
The others are correct brake fluid could only exceed the initial level if it was materializing from another universe. Put a piece of glass over the open cylinder and use a .001" feeler gauge under the glass "feeling" for distortion all around the edge. If it is within .001, it is probably reasonable. If it is then check the cap, it could be bent. You might need to cut a piece of glass to put into the recess. (cut with enough pressure to score the glass with one pass, then tap on the nonscored side to break it. Wear safety glasses, and brush off your hair, eyelashes, and eyebrows with your face turned downward.) Bend the cap flat if it is warped. Use one or more stacked slivers of aluminum cut from a popcan to shim up the cap between the cap and diaphram in the area of the low spot if it is the cast body that is deformed. Good luck, JimN
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
