Re: OT truck problems
Posted by Allan in NE on January 10, 2006 at 05:06:27 from (148.78.243.25):
In Reply to: OT truck problems posted by tn terry t on January 10, 2006 at 03:23:53:
Terry, I dunno.
I would pull the cap, have your wife work the pedal and watch that reservoir.
When the pedal is pushed, there should be a slight amount of artesian(ing) until the pistons move past the intake ports, but there shouldn't be a whole lot of pressure in there to speak of. If there is, I think you have a bad master cylinder.
Are you turning the baffle/cap seal in backwards on itself before you put it on? Lower fluid level over time should pull it outwards.
Hope you get 'er figured out,
Allan
