Re: 400 injector removal
Posted by cmmettler on January 10, 2006 at 16:33:58 from (65.43.151.16):
In Reply to: 400 injector removal posted by bobdod on January 09, 2006 at 15:12:44:
I have tried 2 ways.
On 1 cracked head we cut the injector studs off so we could turn the injectors with a pipe wrench. Once we got them to spin they cane out pretty easily.
On the other head we tool the top half of the injector out and used the screws thru the threaded ears like jackscrews. This worked OK also.
If you get them out remember to also get the pre-combustion chambers out too. You cant buy them any more.
