Re: 300 OVERHAUL, FIRECRATER PISTONS OR NO
Posted by riverbend on January 10, 2006 at 19:54:44 from (208.160.34.3):
In Reply to: 300 OVERHAUL, FIRECRATER PISTONS OR NO posted by DEWAYNE UTRUP on January 10, 2006 at 09:53:55:
These are like any other motor. If you bump up the compression, it will run better with a little higher lift cam if you make sure that everything else is as it should be or better.
