Re: 400 remote valves
Posted by Nat 2 on January 11, 2006 at 04:45:12 from (64.80.108.52):
In Reply to: 400 remote valves posted by scotc on January 10, 2006 at 19:34:35:
It's the same for the 400 and 450 as far as the procedure, except the 450 has holes in the hood, and the controls are extended for easy access. On a 400, you have to remove part of the hood to make the switch.
It's easy. On top of each of the valves is the control for 1 or 2-way. You use a wrench to turn the control 90 degrees to switch it.
