Re: installing 'H drawbar???
Posted by Janicholson on January 11, 2006 at 07:32:13 from (66.173.50.75):
In Reply to: Re: installing 'H drawbar??? posted by Farmer Bob on January 10, 2006 at 17:24:00:
Farmer Bob has it. Do not remove the casting. You need the Pivot Pin as described, and (I think a 3/8 NC X 1-1/4" bolt and a rectangle of mild steel 1"X1-1/2" with a 3/8+ hole in one end to retain the pin from the bottom. (I'd leave it dry to keep from making a lapping compound out of grease and field dirt.)
JimN
