Re: OS 400 M, SM, Motor problem
Posted by Bob M on January 11, 2006 at 11:30:56 from (151.190.254.108):
In Reply to: OS 400 M, SM, Motor problem posted by MagMan on January 11, 2006 at 10:54:11:
Could be the camshaft woodruff key has sheared letting the drive gear "walk" out of time (it's still turning the camshaft but the cam timing is now way out). Or the cam gear hub may have busted then turned partway with the same result.
This kind of failure is not uncommon if the tractor is equipped with cam gear-driven live hydraulics - even for the Super, x00 and x50 series with their "stronger" cam drive gears.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
