Re: Volts to plug
Posted by Janicholson on January 11, 2006 at 17:24:49 from (66.173.50.182):
In Reply to: Re: Volts to plug posted by John T on January 11, 2006 at 14:59:00:
Here is my take on the issue:
The dwell on a low rev 4cyl. will allow coil saturation (given)
The points break and begin the collapse of the magnetism in the coil.
The gap in the plug+ other resistance in the leads cap and rotor make the apparent resistance of the secondary infinite. The magnetism is held back by the increase in reluctance of the "open" windings. Concentrating its effect till the voltage of the gap/s is overcome. the voltage thin ionizes the fuel air in the spark gap and a lower voltage multi spark "duration" jumps the electrodes. (in the primary of the coil, this is all one way into into the condenser. Then the condenser discharges back into the coil (but with not enough intensity to spark), just so that the potential is "worn off" to limit point arcing.
(I've studied ignition traces a long time in theory and application)
A wider gap increases the open circuit voltage. The "lightening" strike across the plug electrodes is from higher voltage and thus drives increased amperage across the gap, (hotter) the duration is about the same because the condenser only acts as a reflector after the spark stops.
Modern plugs in modern engines can have .060+ gaps for this reason, they have better exposure of plasma to unburnt fuel/air.
After the initial setting of the fire the plug could be considered irrelevant, the flame front can never burn that exhaust again.
No free lunch just a more intense use of the lunch that is there.
Just my thinking/experience.
JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
