Re: 1066 more info and to Tractor Vet etal
Posted by Michael Sheik on January 11, 2006 at 17:29:49 from (64.250.199.36):
In Reply to: Re: 1066 more info and to Tractor Vet etal posted by IaGary on January 11, 2006 at 16:03:47:
Something I forgot to mention earlier this evening. The 3 pt works but sometimes when you put in the lower position it does not go down and you have to move the lever back and forth until it is just right and it will lower. Doesn't seem to be any problems in the lift position but no load on it and it comes right up. I am not familiar with how the draft control lever should operate and maybe that has something to do with it. Should it move back and forth easy or hard and should it want to remain in the forward position? Seems as though it is spring loaded. I'll ask dealership (JD) if they can test pressure @ remotes. What should they be?
I really have no use for the duals as will be hay tractor and hate that long axle sticking out there but can't do much about that short of a cutting torch. That not a good idea!!! Guess will live with it if I buy.
Happy to hear from you all and thanks for all the help so far. If you can think of anything else before tomorrow morning please chime in. Still looking and contemplating!!!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
