Re: 1066 more info and to Tractor Vet etal
Posted by K.B.-826 on January 11, 2006 at 17:47:19 from (66.188.194.166):
In Reply to: Re: 1066 more info and to Tractor Vet etal posted by Michael Sheik on January 11, 2006 at 17:29:49:
Try pushing down on the hitch by hand. Some of them won't get started going down without a little weight on them. When checking the hydraulics, first check free flow, should be close to 12 gpm. Next, check max pressure, 1066 could be anywhere from 2000-2500 psi depending what relief valve is in it. Finally, check flow at 250 psi below max pressure, should flow at least 80% of what you got when you checked free flow.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
