Re: best paint?
Posted by Dave_Id on January 11, 2006 at 17:38:06 from (4.242.234.209):
In Reply to: best paint? posted by IHnut on January 11, 2006 at 17:26:24:
You can check out the Paint & Bodywork forum.. Best Paint? Depends on how much you want to spend. An all around good paint would be your PPG Omni line, or the paint that Napa sells. They are both excellent, but you will pay quite a bit more than you would if you bought paint from your IH dealer, which would be adequate if you plan to work the tractor, and not show it. You can go with Dupont and pay alot more
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
