Re: Volts to plug
Posted by Hermit on January 11, 2006 at 17:51:44 from (69.21.48.101):
In Reply to: Volts to plug posted by Dellbertt on January 11, 2006 at 11:37:44:
A couple of years ago I hooked up my '50 M to my Sun machine. My M is 12 volt, 100-110 psi compression, battery ignition system, plugs set at .028 and readings at idle. The firing line voltage showed 5-6 kv. Spark voltage was 2-3 kv with a spark duration around 1.3 ms. As others have said, if you open up the plug gap the spark duration will go down. It's best to find the proper firing voltage and spark duration to produce the most complete combustion at the proper time.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
