Re: best paint?
Posted by John in CT on January 11, 2006 at 18:30:12 from (69.24.45.35):
In Reply to: best paint? posted by IHnut on January 11, 2006 at 17:26:24:
The Best paint money can buy, Dupont Imron. Their single stage will outshine base coat/clear coats. Also, it will resist chemicals the best ( gas spills, brake fluid etc.) Goes on good and covers good too. Only bad part, you should use a fresh air mask / air supply for your own safety.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
