Re: I'm Whipped!!!
Posted by steveormary on January 11, 2006 at 19:42:09 from (216.31.92.91):
In Reply to: Re: I'm Whipped!!! posted by WyoDave on January 11, 2006 at 18:37:51:
Allan,bet you never had so much fun in your life. Well mabe. I had the same problem with my 706. Used heat,chisled the slot,more heat,plenty of liquid wrench,hammers etc. Finally got her loosened up. Used plenty of never-seize on the little tubes and the big ones.
Suggestion. Put the Hydro 70 badge and the 686 badge on your 68670Hydro.
Keep warm and play safe.
steveormary
