Re: M Farmall Rear End stuck
Posted by captaink on January 13, 2006 at 08:51:38 from (66.115.214.56):
In Reply to: M Farmall Rear End stuck posted by Jndrgreen on January 13, 2006 at 07:52:38:
Sounds to me like a brake is hanging up or water (doesn’t take much) frozen in the rear end on one side. Was the tractor setting level? If not, was the side that the wheel turns the high side? If so it might be water in the rear end that has frozen and preventing the bull gear from turning. If it warms up, loosen the drain plug below the PTO until it is loose enough for water to drip out but not the gear oil. This will temporarily fix this problem. If the tractor was setting level, then I suspect that a brake has hung up on the side that won’t turn. The reasoning is based on the following which is assuming the engine is not running and the clutch is engaged. One wheel turning and the other doesn’t means the pinion shaft AND differential spider gears have to be turning. (The differential spider gears must be working for one wheel to turn and the other stand still and since the differential housing must turn when one wheel turns and the other stands still, that means the pinion shaft is turning and the transmission has to be in neutral or the clutch disengaged.) If the spider gears are locking, both wheels would have to rotate the same direction at the same speed. (Their function is to allow the wheels to rotate at different speeds.) If the transmission is stuck in a gear, and the differential is working, the wheels will turn opposite directions, since the pinion shaft and differential can’t turn, the spider gears must or neither wheel will turn.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
