Re: M Farmall Rear End stuck
Posted by jndrgreen on January 13, 2006 at 10:13:38 from (66.251.201.251):
In Reply to: Re: M Farmall Rear End stuck posted by captaink on January 13, 2006 at 08:51:38:
The left brake, (side which won't turn) "feels" like it might be engaged or stuck. The left brake will hardly depress, while the right brake depresses much further.
I hope it is the brakes. I plan to begin working on the tractor this weekend.
Thanks for your input.
