Farmall Tractors Discussion Board
Poping
Posted by Justin on January 04, 2000 at 15:10:43 from (208.196.32.57):
When my Super M reaches operation temp, there is a poping sound thought the exaust. If you take the muffler off that little pop is a little flame. The tractor runs good, has plenty of power. I have rebuilt the head and carabator compently. I now it has nonthing to do with the distibutor. It only pop's every now and then, but only when it's warn, not cold. I've changed the timing and that doesn't change anything. I've adjusted the carbator, that doesn't change anything either. At half throtle the pop stops, or you just can't notice it as much at an idle. I would like to fix the problem. It seems what ever I do,it doesn't slove the problem. Some people told me it's the nature of the tractor. Any infomation would be helpful to slove the problem.
Thanks Justin
Post A Followup
: Re: Poping
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
