Farmall Tractors Discussion Board
Re: Poping
Posted by John IH on January 05, 2000 at 06:05:20 from (207.141.105.2):
In Reply to: Poping posted by Justin on January 04, 2000 at 15:10:43:
My 400 (the same 264 cid engine) used to pop like that more when I used a wide spark plug gap of .030. Now that I run .025 it seems a little better. Another thing to check is to make sure you are getting full spark advance range. If you are not getting 0 degrees TDC at idle and 25 degrees at full throttle your distributor advance weights are sticking and will have to be lubricated or replaced. I ended up replacing mine because the springs were so weak. Sure makes it run smoother.
Post A Followup
: Re: Re: Poping
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
