Re: will super m piston and sleeve kit fit in a re
Posted by JakeF on January 15, 2006 at 11:16:18 from (64.146.188.222):
In Reply to: Re: will super m piston and sleeve kit fit in a re posted by MagMan on January 15, 2006 at 05:21:07:
An M has 3 7/8 pistons and a 4 1/8 bore in the block.A super M -400 has 4" pistons and a 4 1/4 block bore. A 450 has 4 1/8 pistons and a 4 1/4 block bore. You can put 4" pistons in an M but you use thinwall sleaves made for the M block, just as the 450 has thinwall sleaves made for the 400 block. Or you can bore your block .125 and use the 4 1/4 OD 450 sleave set. You can also run 450 sleaves in the M block without sleaves. Jake
