Re: international 354 3pt hitch
Posted by genep on January 16, 2006 at 08:01:51 from (216.96.6.117):
In Reply to: international 354 3pt hitch posted by jim23377 on January 16, 2006 at 06:01:28:
I have a 354 and just finished going through it with new o-rings, gaskets, etc. It was hicupping as you describe. Mine would leak down with the isolator valve closed, although not as fast as with it open. I found a bad o-ring on the lift piston, an egg-shapped seat where the relief ball sets, and a slightly scored relief ball. Also several of the o-rings had flat sides on the mating surfaces. It's now holding great. I used an IH Blue Ribbon service manual to guide me though the process. This book shows that fluid is trapped in the cylinder, the relief valve, and the position control valve when the position control valve is in neutral (not raising or lowering). If yours holds with the isolator valve closed it is probably one of those valves. Whe you get it torn down that far it makes sense to re seal the whole thing.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
