Re: Wrong starter on Super A???
Posted by paulntxk on April 08, 2009 at 21:05:26 from (75.88.216.142):
In Reply to: Wrong starter on Super A??? posted by paulntxk on April 08, 2009 at 19:05:33:
It DOES have hydraulics, it also still has a magneto (not hooked up) although it has been switched to a coil. Did Super A's have an ignition coil or magneto? I always thought A's had magnetos and Super A's had a coil. Is that correct? The starter rod is the type with a loop on the operator end (like on my 100) that you PULL. I once had an A and the starter rod had a right angle on the operator end and you PUSHED it to run the starter. The seat bracket has been replaced with a homemade thing (so, no "A" ID plate) and there is NOT an ID plate on the left side of the engine where it is on my 100. What do I have? And can the starter case be turned around??? Thanks
