Wrong starter on Super A???
Posted by paulntxk on April 08, 2009 at 19:05:33 from (75.88.216.142):
I recently bought what I think is a Super A. The starter pull rod was not hooked up and it appears that the starter may be the wrong starter, the saddle switch is mounted on the front portion of the case, so the button faces forward. Is it possible to turn the case around so that the switch would be on the rear with the button facing rearward?
