Re: Remote Hydraulic Controls on 330U
Posted by TDK on January 16, 2006 at 09:03:53 from (205.188.116.133):
In Reply to: Remote Hydraulic Controls on 330U posted by Tweeter on January 16, 2006 at 06:57:56:
You have to remove the valve or valve plate to replace lever, so you will loose fluid. Wait until you change the fluid and use new o-rings.
