It DOES have hydraulics, it also still has a magneto (not hooked up) although it has been switched to a coil. Did Super A's have an ignition coil or magneto? I always thought A's had magnetos and Super A's had a coil. Is that correct? The starter rod is the type with a loop on the operator end (like on my 100) that you PULL. I once had an A and the starter rod had a right angle on the operator end and you PUSHED it to run the starter. The seat bracket has been replaced with a homemade thing (so, no "A" ID plate) and there is NOT an ID plate on the left side of the engine where it is on my 100. What do I have? And can the starter case be turned around??? Thanks
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
