Re: SMTA Wide Front Question
Posted by Bob M on January 17, 2006 at 07:59:52 from (69.205.118.76):
In Reply to: SMTA Wide Front Question posted by Brian Schmidt on January 17, 2006 at 07:28:05:
Well that"s only partially true...
The Super M factory WF has the tie rods behind the axle. So the break from the old style (tie rods in front) WF axle had to have been at the start of Super M production or before - ie. at least 2 years before the first SMTA was built.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
