Re: Remote hydraulic valve
Posted by Hayfarmer on January 17, 2006 at 12:39:44 from (12.160.163.105):
In Reply to: Remote hydraulic valve posted by wsmith on January 17, 2006 at 08:48:12:
I rebuilt one of these valves a few years back. There shouldn't be oil up high enough to squirt or even run out of the area around the handle. There were either 1 or 2 o rings on spool. If you take it apart you can probably match them up most anywhere.
