Re: Remote hydraulic valve
Posted by Jeff Grodey on January 17, 2006 at 13:26:46 from (198.45.19.20):
In Reply to: Remote hydraulic valve posted by wsmith on January 17, 2006 at 08:48:12:
I took mine apart last weekend because the spool froze up. There is only one o-ring seal. You may also have to make an adjustment on the screw that runs through the middle of the spool. This controls how far the spool travels inside.
Because mine is so messed up, can you tell me what hose hooks up to what hole on the valve? There are three outlets. Mine has the middle outlet going back to the cylinder and the two on the outside have one hose connected to both holes, so that it goes right back into itself. Is that right? Thanks...
