Re: 706 Questions T.Vet
Posted by MN Scott on January 17, 2006 at 20:13:49 from (206.9.216.56):
In Reply to: Re: 706 Questions T.Vet posted by the tractor vet on January 17, 2006 at 17:05:31:
Used the Victor gasket. I did run a bottoming tap in the holes and washed them out with brake clean and air two times. Head bolt treads got a very light coat of engine oil. Sure hope I don't have to pull the head again, only thing I could do differant is use coppercoat. I guess if there is no coolant in oil I will run it awhile and see what happens.
