Re: Starting problems with 300
Posted by El Toro on January 18, 2006 at 18:37:14 from (205.188.116.133):
In Reply to: Starting problems with 300 posted by Josh K on January 18, 2006 at 17:59:18:
You should have a terminal on the key starter switch that only has voltage when the key is in the start position. You should have another terminal on the switch that feeds voltage to your
ignition. Whenever the switch is in the on position there should be voltage here at all times. Take a volt meter and check for voltage
on the terminal on your switch that feeds the ignition when cranking. If there's no voltage
to your ignition during cranking your switch may be the problem. You said the engine fires when you let off on cranking. Hal
PS: Is this a 12 volt system with a ballast resistor? It can cause this if resistor is defective.
