Re: International 826
Posted by K.B.-826 on January 18, 2006 at 22:01:33 from (68.115.111.89):
In Reply to: International 826 posted by Doony on January 18, 2006 at 21:41:07:
Sounds like you're talking about the power steering lines. Transmission/Hydraulic dipstick is located about where your right foot would be while sitting on the seat. Fill until it at least touches the stick with a good quaility hydraulic oil, such as Case-IH Hy-Tran. Once you get those lines fixed, drain the transmission, change the filter, and refill with new fluid. Holds about 17 gallons.
