Re: 350 Utility Steering
Posted by PAULIH300 on January 19, 2006 at 09:22:35 from (152.163.100.65):
In Reply to: 350 Utility Steering posted by BEWILDERED on January 19, 2006 at 09:03:12:
The steering shaft has a worm on the end that engages one of the two steering "pitman" cross shafts,which in turn is geared to the other "pitman" cross shaft.Sounds like one of the "Pitman" shafts lost its teeth where it engages the other.Some of those parts are no longer available,some are VERY expensive.This is why the front tires need to be ribbed and fully inflated,and only steer when under movement.These boxes are rather easily damaged and can drain your wallet.....
